cam choice for 305...need some help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-11-2013, 06:50 PM
I was unaware of that, rear is out of a 95 6 speed z, guy I got it from told me 355s so I'm guessing they're 342s? I was thinking of going xe262 with 1.6 rockers but I know the stock heads don't flow well, I've never done any port work..
  #17 (permalink)
Old 08-11-2013, 06:53 PM
I just know silvolite flat tops, .28 gaskets...I'm guessing 9:5:1 cr...
  #18 (permalink)
Old 08-11-2013, 07:22 PM
jokerZ71's Avatar
Wrench Turner
I would definitely ask the builder,becuz,IIRC,& sometimes I don't,the Silv-o-Lite's only come in a 1.54 compression hgt.If the block hasn't been decked any & they use a .028 gasket,your piston could be .073 in the hole.Even @ 0 deck,you'll be .048.
  #19 (permalink)
Old 08-11-2013, 07:27 PM
Banned
Originally Posted by F-BIRD'88 View Post
Best check the axle ratio as a 3.55:1 ratio does not exist for the 7.5" rear.
factory for that car is 3.23. Optional is 3.73. Most are 3.23:1 (5 speed)
rear gears for most 80's 3rd gen f bodys are 3.23 and 3.42
don't remember 3.73 ever being offered until you got into the firehawk
  #20 (permalink)
Old 08-12-2013, 07:06 AM
Banned
O/P
is your 305 roller compatible block?
not sure if the 86 was or not.. maybe someone (F-BIRD88) CAN TELL YOU ,if so I'd run a roller as it's cheaper to save now than to loose a lobe..
the 85/86 305ho with carb has a blower motor and duct work to blow on the carb to keep vapor lock/boiling the fuel at bay.. make sure you have this.. as the cars engine bay is cramped and even the hood with 4 vents(two at nose and two at back sides) don't help enough when parked..
my 86 when the relay went would take forever to start because the fuel boiled out..
  #21 (permalink)
Old 08-12-2013, 07:12 AM
I have a 4 inch cowl hood for it, and the a/c is all gone, will I still need it? Would I have to do the same ammpunt of head work for the xe256? How much would the vortec heads have to be milled?
  #22 (permalink)
Old 08-12-2013, 07:48 AM
Banned
no,
Cam Choice 96Dually Engine 17 08-19-2012 05:00 PM
cam choice??? markzepp820 Engine 8 03-04-2010 05:05 AM
cam choice jason hood Engine 0 10-25-2009 11:03 AM
Cam choice for sbc 305 stoney 81ta Engine 6 06-27-2009 09:58 PM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 06:05 PM
