cam choice for 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2008, 10:10 PM
yevgenievich's Avatar
Last journal entry: pictures, try#2
cam choice for 327
I will have to rebuild a 327. It's 1969 block, and i will be using double hump 041 heads. I am going to clean them up and put them on. Plan is to go with forged pistons and maybe forged crank. On the top will be rpm air gap intake with 750 cfm edelbrock carb. I am trying to decide on what cam to put into it. It's not going to be a daily driver, but once in a while fun ride or go to either auto-x or drag strip. For now will be using th350 and 3.73 gears.
Two cams i've been looking at so far:
Isky 201025
http://store.summitracing.com/partde...5&autoview=sku
and Lunati 60103LK
http://store.summitracing.com/partde...K&autoview=sku
Heads look like they can be used after a little clean up
Old 09-07-2008, 10:31 PM
Weight of the vehicle? tire height?
Old 09-07-2008, 10:38 PM
it's going to be about 3300 with driver and for drag strip will be using 275/60/15 back and 205/60/15 front. Also for th350 until i get the muncie going to have a 2500 or 3000 stall
techinspector1's Avatar
Wiki Edits: 326
The first cam will require between 10.5:1 and 12.0:1 static compression ratio.
The second one will require between 9.5:1 and 11.0:1.
Old 09-07-2008, 10:42 PM
i think i should be able to get 10.5:1 with flat top piston. i was trying to see if there are better cam choices out there or which one of them is better.
Old 09-07-2008, 10:48 PM
Wiki Edits: 326
Best thing to do is get all your information together and phone a couple of cam grinders. Talk with the tech guy there and get a recommendation based on what you want the motor to do.
283 cam choice JohnyR17 Engine 4 01-08-2008 06:30 AM
383 cam choice HSR383TPI Engine 13 11-10-2007 09:11 AM
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 02:58 PM
cam choice??? ko.17 Engine 9 03-20-2005 12:12 PM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-21-2005 11:03 PM
