cam choice??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 01:15 PM
cam choice???
hi, i am trying to decide whether or not to change from a flat tappet cam to a roller cam set up, but i am not sure if the hp gains will be enough to justify the $$$. my current cam has duration @ .050 of 230 and 480 lift. last year the car was on the dyno and put out modest hp and torque. 250 hp @ 5500 and 290lb/ft @ 2300 rpm. i have since replaced my camel heads with vortec(600 lift springs) and my rpm performer with an air gap intake. the car has 4:10 gears and a 2500 stall. i am interested in a roller cam set up but don't know if A) it's worth the price for the hp gains and B) will i lose my early peak torque. how much hp can realistically be expected from a roller cam with specs such as 225-230@ .050 and 500-510 lift. keeping in mind the i can achieve the lift numbers by simply adding 1.6 rockers.
thanks for your time
keith
Old 03-19-2005, 02:15 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
You need to provide a lot more info. Please detail your set-up.
Old 03-19-2005, 02:27 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
2500 stall
2500 stall isn't much when you start talking rollers. I am not a fan of 1.6 rockers. But under your circumstances. Its the way I would go. You would get about .513 lift which is still a little high for your convertor.
Old 03-19-2005, 03:49 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Usually on a street motor like yours, you can assume around a 20 hp increase with the roller due to the reduction of friction. If you got a cam that was roughly the same size, it should not hurt low end performance. The 1.6 rockers would be a good cheap way to go, but overall, the roller will make more power. Some things to think about before you spend $600 on a roller setup, do you have a good carb/exhaust/ignition? Also, how well does your car hook up now. If you are not getting the power to the pavement now, a new cam will just make that worse. Rollers are great, but if you have other places where the money can be spent, I would consider the 1.6's and focusing on other things.
Adam
Old 03-19-2005, 04:28 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
that stall would be more than enough for that cam.
here is a vortec headed engine with a 224@.050 & 510" cam
clicky keep in mind this had the wrong valve springs limiting it to 5000 rpm
Old 03-19-2005, 04:44 PM
cam choice
hi, not sure exactly what info you're looking for, it's a 350 30 over, not sure exact compression ratio. vortec heads stk valve sizes, 2500 stall, i have both a 600 and 750 cfm holley carb, headers, 2 1/2 " exhaust, air gap intake, current cam 230, 480 lift, with this cam i was just going to add 1.6 roller rockers but i am thinking that while the heads and intake are off it would be a good time to change cam if that's what i wanted to do. not sure what else about the engine i can tell you.
Old 03-19-2005, 04:54 PM
Adam
hi, when on the dyno with old set up the 600 and 650 performed pretty equal. the 750 not as well. this year with all the new parts i plan on trying all 3 carbs again. i will also be putting on a pair of flowmaster super 40's to help the exhaust side. the car already has headers. as for the ignition, it may be lacking as i currently use an accel super coil. the car has traction bars and seems to hook up well. just thinking that if i am going to change the cam and lifters, now is the time with the heads and intake off.
Old 03-19-2005, 04:56 PM
thanks for trying nxs, but i can't seem to open attatchment.
Old 03-19-2005, 05:54 PM
NXS's Avatar
NXS NXS is offline
It idles well with a stock 700r4 converter and has plenty of power to flat smoke the tires..
Old 03-20-2005, 12:12 PM
firestone's Avatar
In that case, If you have the money to spend, I think a roller would be the next logical step. I would consider the XR276HR .502 .510 lift 224 230 @.050 1900-5600 RPM. With this roller cam, you should be close to 400 hp.
Adam
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-21-2005 11:03 PM
Another Cam Question: What To Use? Chevy21 Engine 17 10-27-2004 04:04 AM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
I think we made a cam mistake! Jmark Engine 11 12-30-2003 10:32 AM
