-   -   Cam Choice with CR of only 8.4:1 (http://www.hotrodders.com/forum/cam-choice-cr-only-8-4-1-a-18809.html)
meschnebly 06-30-2003 08:36 PM
I'm working on a mild build of a 1977 305. I've got a Edelbrock Performer intake with an Edelbrock 600 4bbl for it. I would also like to put a little better cam in it while I've got it apart. I been looking at a couple of cams (Crane Energizer 274H06 and CompCams Magnum 270H) but it seems that they say you need a compression ratio of at least 8.75:1. This motor has a CR of only 8.4:1. I really dont want to do any head work on this motor as its only going to last me a year or so. Would one of these cams not work for me or would you recommend something else?
Mike
OldBucsFan 06-30-2003 09:08 PM
Your cr is very close.....If they are available for your application, go with a thinner head gasket. That will boost the cr a little.
78 monte 06-30-2003 11:43 PM
List all your specs rear gear,stall speed etc... or call a cam company.Having a cam thats too large for your compression will kill bottom end torque,but with say a steep gear,or a real light car or a 4 speed you can go a little bigger on cam size.
I run a XE262(218/224@050) with true 8.6:1 in a 350.
meschnebly 07-01-2003 06:20 AM
Sorry about that. It's a 1977 Monza 2+2 so its pretty light. It has stock gearing and I think it's about 2.29:1 so.... not too good. In the future I am putting in an Auburn Posi with better gearing and Moser axles and I'm in the process of building a 383 stroker with a TH350 tranny but that wont get finished for at least a year. I wont be using this cam in the new engine. The last thing I want to do is loose low end torque. What do you guys suggest?
Mike
meschnebly 07-01-2003 12:28 PM
Oh, one more thing. It has a stock converter in the tranny.
Mike
78 monte 07-01-2003 12:54 PM
I'd suggest the summit K1102 204/214@050 420/442lift 112 lsa.Its the same as the edelbrock performer cam,but for cheaper.It'll have a smooth idle but is a nice torquey cam.We had one in a 305 w/ a Torker(totaly wrong) and 3.55s and a tall tire an it run nice.
mstngjoe 07-01-2003 01:58 PM
Take a look at the Comp Cams XE series. They have some fast ramps that build great cylinder pressure. Should work very good on low cr engines.
meschnebly 07-01-2003 02:57 PM
Thanks for the suggestions. What do you guys think about the XE268H 224/230@050 477/480 lift 110lsa? Think that is too big? I'm kind of looking for the most bang and cam sound out of this motor for what it is.
Mike
jimfulco 07-04-2003 01:15 AM
Too much cam & too little compression. I did a 350 w/224* cam & low 8's compression many years ago. Didn't work well at all.
andybird 07-04-2003 02:16 AM
just use thin head gaskets to get the compression up, if it's only going to be with you for 1 year, why bother putting money into it at all, just build a 350 like you know you want to
meschnebly 07-04-2003 08:48 AM
Yep, it looks like I will have to stay with what I have in it or use a RV type cam. The cam that Comp Cams recomended to me was little more than a stock cam. I was hoping to have a little fun with this engine for the time I have to use it but..... I already have the intake, carb and headers for it so that's no expense and I was just hoping I could find a cam that would give it a little more go.
Mike
mstngjoe 07-04-2003 12:27 PM
What cam did Comp tech recommend?
meschnebly 07-05-2003 03:41 PM
I'm sorry I meant Crane Cams and they recommended the PowerMax H-260-2 cam and the description is "smooth idle, daily usage, off road, towing, economy". I guess it's better than stock but I was hoping that I could use a little more cam than that.
Mike
meschnebly 07-06-2003 03:01 PM
I also noticed that Edelbrock has a Performer Plus cam that looks like it might work for me at such a low CR. Think it would be much better than the stock one?
Mike
jimfulco 07-07-2003 01:46 AM
Both of those cams have 204* intake duration (at .050"). The Crane has a little more lift, & may be slightly more aggressive (less seat-to-seat timing). The difference is not very much, and either would be noticeably better than the stock 305 cam.
