cam choice help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2003, 07:04 AM
Crazy d's Avatar
New Member
Post cam choice help
hi i have a 350 with edelbrock performer rpm. setup.Heads,intake,cam,and carb.
carb 600cfm
cam 234,244dur@.50 and .488&.510 lift.
running 9.5 comp car has a 700r4 with 3000 stall and a 4.56 rear gear.b&m ratchet shifter 3" exhaust with flowmaster 40 series and 2 cats all 3" in and 3" out.msd ingnition with blaster 2 coil
pushing arround 410 hp or so.any thing you guys can think to get more hp. love some input.
thanks..
oh yeah passed emissions test...
Old 05-11-2003, 07:30 AM
Post
You'll gain a little with roller tip rockers, not much though. You didn't mention headers, do you have headers? How much do you want to spend and how much work do you want to do and are you want strip type power or highway speed?
Old 05-11-2003, 02:08 PM
Crazy d's Avatar
New Member
Post
i have cran roller rockers ,headman headers and i like to drag.can't get the tires to stick bfg radial ta 295/50/15 25psi.
Old 05-11-2003, 09:01 PM
black66's Avatar
www.airriderz.com
Post
What size heads are you running?? Is your intake and heads port/polished and matched?? Are you running a roller cam or flat tappet?? Roller cam with give you around 40 more horsepower just with the cam.
I was running a similar setup as you are now. I recently changed to a roller cam. Pumped up my heads and port and polished. I have 10.5 compression and run 13.48 at the track in my 66 Impala...I am pushing 485hp at the rear tire. Not bad for a 5100 lb car......
www.teamche.com
Old 05-11-2003, 09:56 PM
Post
i was told that a torker single plane intake will make more power and u could put a 750 on ur setup 4 more power it depends on how much u are willing to spend u could change out ur pulleys with some march performance pulleys 4 up to 20hp well good luck jj
Old 05-14-2003, 09:22 AM
Crazy d's Avatar
New Member
Post
thanks for your help.
Old 05-14-2003, 02:23 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Post
there's nothing like a set of slicks! If you can't trailer the car, there are a ton of great street slicks out there. Mickey Thompson's et streets are pretty much slicks that are dot legal. If that's a little too much, Super Chevy did an article on DOT legal slicks, and found BFG Drag radials to be great.
Black66 is also giving some great advice. The power is in the heads!
Old 05-14-2003, 02:37 PM
ztoy's Avatar
speed freak
Post
you can call comp cams and answer their questions and they will give you their recommendation as to the cam best suited to fulfill your needs. They have a website where you can get the phone number.
Old 05-16-2003, 03:56 PM
Crazy d's Avatar
New Member
Post
thanks guys
Old 05-17-2003, 05:21 PM
Crazy d's Avatar
New Member
Post
d
