Cam choice for quick car? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-10-2008, 01:04 PM
I put 64cc dart iron eagle heads on a 350 goodwrench engine (12cc pistons) and made 9.3:1 cr, used a compcam 260H (212/212), and it runs on 87 octane with 38 total degrees of timing, 2000 stall, 2.87 gear, and 3000 pounds.
  #17 (permalink)
Old 07-10-2008, 07:54 PM
Team Revolution
Well I bought a comp cams 260H last night. 260 int./260 exh duration. .440/.440 lift. I think this will be the best bet for what we want. And later on we can do a head swap to bump up the compression a little bit.
  #18 (permalink)
Old 08-11-2008, 08:46 PM
I'm running a 78 Camaro XE 256H 3.23 and it drives fine, sounds good at 800 idle. Not sure how heavy your car is (mines 3600) but i think you would be safe to run a 262H if you changed your gears.
283 cam choice JohnyR17 Engine 4 01-08-2008 06:30 AM
help with a cam choice powerrodsmike Engine 24 07-30-2006 10:42 PM
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 02:58 PM
383 cam choice markn Engine 10 07-02-2004 01:29 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
