With that compression ratio I'd be leaning toward the larger cam, with the smaller one you might have trouble running it on pump gas. There were some posts on dynamic compression ratio a while back, you should look them up, otherwise read here
http://www.empirenet.com/pkelley2/DynamicCR.html |
I built my 383 with less compression and used Comp XR282HR hydraulic roller cam, which has 230/236 duration and .510/.520 lift with 1.5 rockers, I only have about 9.8:1, Sportsman heads, and while it's in a boat I don't think I would have any streetability problems if I dropped it in my Chevelle. It idles about 1000 rpm, could probably get it lower with a little more creative timing but I don't worry about that on the water, and it pulls 12 inches of vacuum, not really enough for power brakes but a vacuum canister would take care of that. I think my dynamic comp ratio ended up about 7.8:1, might be a tad low for max power, but it runs on 91, and boat engines are a little different in that they're always under a load, and you wouldn't hear it knock with the open headers that are on it, and I don't have any problems or see signs ot detonation when I check the plugs.
with a manual transmission, low gears, and 11:1 compression you can pretty much put whatever cam you want in there. I would go for the most radical of the 3.
cams
If you are going to drive it on the street you would be better off with a cam with 230-240 duration. Also with the 11:1 compression you will probably will not be able to use pump gas. I think most 383 motors reach peak hp and torque around 5800-6000 rpm so look at the power range of the cams. Good luck.
that's the kind of reading they use to stuff pinatas... go with the 286, your heads and intake pretty much limit anything bigger due to their restrictive flow. If you'd change them then I'd be all for the bigger one, but with what you have its just too much of a mismatch. Even if it does flow like a performer... those are intakes designed for low end torque, not high HP. |
I don't get it??? The reading is sweet? |
No, its just not good for much else... maybe hampster cages or backing for BB gun targets... |
| 383 stroker clearances/specs | randywr | Engine | 5 | 01-07-2008 08:57 PM |
| 383 cam choice | HSR383TPI | Engine | 13 | 11-10-2007 09:11 AM |
| smart cam choice? opinions valued. | classic keith | Engine | 21 | 04-10-2005 08:26 AM |
| Cam choice,, Please help!! | Lthompson | Engine | 23 | 02-09-2005 06:05 PM |
| valve adjustment 383 stroker solid lifter cam | 73luvdrag | Engine | 4 | 05-15-2004 03:01 AM |
