cam clearance in a 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 07:57 AM
hey fellas got a little problem here. i have a comp cams 292h "244 at .050" magnum. the problem is this i have heard that my rods will smack this cam as it turns. is there any truth to this or is it a bigger cam that does this. i have the block almost ready to put back and want to do it right the first time. if so , what would be a good clearance between the rods and the cam. ADAM
Old 09-24-2006, 08:09 AM
If this cam was not ground on a small base circle, you may well have clearance problems. Check the serial # of the cam with Comp's tech reps to determine whether the cam was ground on a standard or small base circle core.
Paul
Old 09-24-2006, 08:26 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I did a 383 a year ago and the rods did hit the cam and the block and the oil pan. I was able to get the rods to clear the cam by grinding some clearence on the rod. It hit at the very edge of the rod were the rod bolt goes thru. Then I had to grind the block for the rod bolt nuts to clear. The oil pan got the clearence it need with a small ball peen hammer. Lots of extra work but no extra cost. I would assemble the short block with out the rings to make sure it all clears. Then have it balanced. I put about .060" clearence between the rods and cam.
Old 09-24-2006, 09:33 AM
It's not the fault of the cam. The cam will fit and clear with stock GM rods designed for a 3.75" stroke, it's the non-stock rods that cause the clearance problems. Do you use the stock GM rods designed for this application? I see you've pretty well described the cam, can you describe the rods?
Old 09-24-2006, 11:45 AM
rods
eagle i-beam with arp waveloc bolts, am also considering scat rotating assembly with h-beam rods.also with waveloc bolts
Old 09-24-2006, 11:48 AM
THANKS A MILLION, was there plenty of room for the crank throws? i'm scared to death that i won't have enough clearance and under load the crank will hit
cam for 383 dejo Engine 24 09-15-2006 06:59 PM
What cam for 383??? 89SDime Engine 1 02-28-2006 05:29 PM
cam curious for 383 stroker? superstankmo Engine 8 11-16-2005 07:56 PM
My 383 Buildup, Main Bearing Clearance cobra621 Engine 8 09-25-2005 03:49 PM
need cam suggestions for my 383 build TCAMARO Engine 10 12-23-2004 04:51 PM
