Cam compatability - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2011, 01:49 PM
Cam compatability
Ok guys I need some direction here. I have an 86-88 4 bolt that I am building into a 383 stroker and have run into a little problem. Everythng I bought and am able to swap over from my existing block is for a 2 piece rear main and the newer block is a 1 pc. When I went to install the cam from my other engine(which only has 3 dyno run hrs on it) I notice that the front where the cam gear goes is different. This is when I actually looked and ran the block numbes and found out it's the '86-'88 roller motor. My question is this: Can I install the hydraulic flat tappet cam and new lifters and if so are there any cons to doing this. Secondly, if I can use teh hydraulic cam do I need to buy some type of plate for behind the cam gear so it won't rub as it is totally flat behind where the gear goes unlike the older block that has a 3/8" raised shoulder. Thanks for any help you can throw my way as this build has been trying to say the least.
Old 03-26-2011, 02:06 PM
Cam swap
I just spent over $230 bucks on the cam when I put it in the last motor and ran it on the dyno for the 3 hours. The cam is good with absolutely no wear or heat stress since it was only in a short time, but I plan on throwing out the lifters if I can do the swap. Just trying to use what is still good if I can. I don't know anything about roller cams, but from looking at Summit and Jegs I would be looking at around $475 for cam and rollers at a minimum--is that about right?
Old 03-26-2011, 04:30 PM
Well this is gonna take me a little bit of time to figure out which rollre cam combo to get. The other cam, don't have the spec in front of me but pretty sure Comp cam with 255 int/265 exh lift and 540 int/563 exh. I run 72cc Aluminum heads, holley 650 vac secondaries, and a Weiand 142 blower at 7.2lbs boost so pretty sure that was the cam the program came up with to make the power. I don't have a good machine shop anywhere around so have to make calls to get some help on where to get the best deals on some NEW parts I guess, I will check out the ones you mentioned in your thread also. Only good thing is the old block and parts will go for a couple bucks towards the new parts. Thanks for the info
Old 03-26-2011, 05:08 PM
Machine shop had the 4-bolt with all the work already done (bored .030, fluxed, honed and freeze plugs installed) for $200 so I figured what the heck go with the stronger 4-bolt at that price. Beginning to think that was a bad idea. Just sucking up the cash now, was hoping to get it going in the next 2 weeks-but since I need to spend for the cam and lifters that will get pushed. I'll let ya know what I decide on for cam/lifters. I'm sure it will be hydraulic not solid as I have enough engine nosie with the blower, gear drive and exhaust. Oh my bad I put 650 Holley, it's 750 vac sec and I believe 74 jets for mains and 69 for secondaries--least I think that is what the sheet said when we were done. That's all gonna change when I get it back on the dyno and get it tuned though
GMC 292 starter compatability....?? PairOf69's Engine 2 03-15-2011 03:17 AM
Cam Compatability Question Regular6d Hotrodding Basics 1 11-09-2010 06:01 PM
Chevy Compatability DScott9160 Engine 2 10-18-2003 12:40 AM
Powerglide Compatability drgnwgn289 Hotrodders' Lounge 1 04-03-2002 05:13 PM
Powerglide Compatability drgnwgn289 Transmission - Rearend 11 04-03-2002 09:46 AM
