cam and compression question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2008, 04:13 PM
Compression questions
I was running 12.7:1 compression with 58cc chambers ,180cc runners, 202/160 valves. I just purchased some nice aluminum heads 210cc runners, 205/165 valves, but they are 64cc chambers. This brings me down to like 11.5:1 compression if I did my math right. The cam I am running is - RPM Range: 3000-7300 Advertised Duration: 287/298Duration @ .050: 254/263Lift: .534/.555 Lash-Lobe Center: .026-105c. The question is how much would I be losing power and torque wise. should I buy new pistons to bring the compression back or save the heads? Is either worth it?
Old 04-13-2008, 04:15 PM
IT SHOULD SAY SHAVE THE HEADS, NOT SAVE THE HEADS.-SORRY-JT
Old 04-13-2008, 04:38 PM
cam question
This engine is going in a street 1968 camaro, I do not know what gear yet. It does have a power glide tranny. We are going for a sleeper. I want a nice cam but not alot of noise for everyone to know. The engine is a 383 stroker,aluminum heads,205/165 valves, 210 runners,12.5:1 compression. Need suggestion on a intake/carb combo also. What do you think?
Old 04-13-2008, 04:42 PM
compression questions
How bout thinner head gaskets. Or if you can find a good shop, you could tig weld the chamber,then polish to match.
Jmark's Avatar
Can't comment on the cam selection but I hope you live close to an airport so you can buy gas! LOL 12.5:1 compression???? Ouch!
Old 04-13-2008, 04:47 PM
hmmmmm....
Really, Tig to make the chambers smaller? I did not think of that. What does that cost?
Old 04-13-2008, 04:52 PM
gas
ITS NOT A DAILY DRIVER, JUST A WEEKEND CAR. YOU KNOW A TRIP TO THE DAIRY QUEEN AND MAYBE A RACE BACK HOME
Old 04-13-2008, 04:53 PM
Oh Yea
tHOUGHT ABOUT 125 SHOT OF NOS. i have it here just sitting aroung.
Old 04-13-2008, 05:06 PM
DoubleVision's Avatar
The power gain from the better heads will far overshadow the compression loss, I would leave what you have alone, as 11.5:1 is plenty of compression for your combo.
Old 04-13-2008, 05:19 PM
Jmark's Avatar
Just incase you are curious, I merged the two similar threads.
Mark
Old 04-13-2008, 05:20 PM
a good tig welder is gonna be 70-80 bucks an hour. Not a cheap alternative. But if you know how thick your compressed head gaskets are, you could use a thinner one and gain 2-5 tenths of a point which would put you back closer to what you had. What are ya doin with 12.7 compression anyway??
Old 04-13-2008, 05:42 PM
THIS IS A TOTALLT DIFF MOTOR THEN THE COMPRESSION QUESTION! I ASKED TWO DIFF QUESTIONS AT THE SAME TIME AND THEY ENDED UP IN ONE THREAD.
Old 04-13-2008, 05:44 PM
8TH MILE DRAG STRIP,2600 LBS CAR
Old 04-13-2008, 05:48 PM
Originally Posted by F-BIRD'88
based on your info; if the cr was 12.7 before then the cr would now be 11.74:1
assuming the same head gasket volume.
So its less than 1 cr difference. Theory says for every 1cr increase you get approx a 4% increase in power. Actualy the % increase is not quite linear.
You actually see less than a 4% gain at higher cr's per unit increase.
If you're running pump gas You don't want 12:1 anyways.
If you can actually tell the difference in power and feel a lose of low end torque and say the cam is now "straight up" on 105 in C/L, you could advance it say 5deg to enhance the torque. You can also make the ignition advance curve more aggressive if not already so.
Does this motor have a flat top piston or a dome piston?
THIS MOTOR HAS POP UPS AND RUNS ON 116 OCTANE
Old 04-13-2008, 06:12 PM
Jmark's Avatar
OK, I goofed. I thought your two very similar posts were the same one in two different places. I merged them to help keep people from spending time answering them in two different places. Sorry. I'll leave now and go pull some weeds or something.
Mark
cam and quadjet question derek32303 Engine 8 06-12-2007 04:59 PM
Chevy cam question buzz1961 Engine 1 02-21-2007 04:02 PM
Another Cam selection question NWayne Engine 17 02-01-2007 12:28 AM
cam question dboyett38606 Engine 8 01-23-2007 02:13 PM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
