Cam and compression ratio...will it work or is it to small? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2010, 06:14 PM
I have a comp cams extreme 4x4 cam, specs are
comp cams X4270H
1800-6000 operating range
lobe-center angle 111
intake centerline 107
duration 270 intake 278 exhaust (advertised)
226 int 234 exh @.050"
intake lift .48
exhaust lift .498
Will this work with 10.5:1 compression or is it to small and will it cause to much cylinder pressure? thanks
Old 09-15-2010, 06:21 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
You will need to post more info on the total package, no one can answer this question yet.
Old 09-15-2010, 06:31 PM
Scat crank
AFR street 195cc runner 64cc chamber
10.5:1 compression (proposed)
Weiand dual plane stealth intake
770cfm holley carb
comp cams X4270H
intake lift .48
exhaust lift .498
1.6 roller rockers
hooker headers
its in a 75 K20 pickup with a 4 speed manual 4.56 gears, 35" tires
desktop dyno estimates 51 degrees valve overlap based on the comp cams spec sheet.
Old 09-15-2010, 07:18 PM
Originally Posted by 383_Gladiator
383
Scat crank
770cfm holley carb
comp cams X4270H
intake lift .48
exhaust lift .498
1.6 roller rockers
hooker headers
Go here http://www.kb-silvolite.com/calc.php with this data and plug it into the DCR calculator. 8 is street-able with 91 octane. 8.5 is getting iffy, but a manual gear box and stiff gears will let you stretch it on the high side.
Bogie
Old 09-15-2010, 08:02 PM
techinspector1's Avatar
Wiki Edits: 326
Let me help you out a little here, because first you have to find the intake closing point at 0.050" tappet lift. I'm able to do this pretty quickly. The figure is 40 degrees for that cam, so adding 15 degrees to that means you have to enter 55 into the calculator and are rewarded with a DCR of 9.009:1 at 10.5 SCR with 3.750" stroke and a 5.703" rod.
My first impression is that there is no pump gas on the planet that will allow operation at 9.009 DCR without the motor detonating like shaking a can full of rocks. Needs less SCR or more cam. Even if the DCR were in line, I would err on the side of caution (like maybe 8.0:1 DCR with a very tight squish) because of the excellent cylinder-filling characteristics of the AFR heads and Stealth intake.
I might be full of beans, but that's my take on it.
Old 09-15-2010, 11:37 PM
What would you say the highest compression I could go with? Will be running 93 octane
Old 09-16-2010, 12:10 AM
Can anyone reccomend a good comp cam for use with 10.5:1 or 10:1? Truck will be used off-road and a mug drags so a good torque down low off the line would be nice with decent power up top to keep up wheel speed once the motor revs out
Old 09-16-2010, 02:45 AM
Wiki Edits: 326
Here's the power, but I don't know if it will operate on 93 octane....
10.5:1 SCR
Crane 110742 flat tappet hydraulic cam and kit
http://www.summitracing.com/parts/CRN-110742/
1 3/4" open headers
RPM HP TQ
2000 143 376
2500 190 399
3000 243 426
3500 307 460
4000 372 488
4500 431 503
5000 485 510
5500 516 493
6000 530 464
6500 527 426
7000 512 384
Peak volumetric efficiency 99.7% @5000
Peak BMEP 200.9 @5000
Call up the tech guys at Crane and discuss this with them. They may have a completely different direction for you and some way to lighten up the cylinder pressure and make hp at the same time.
http://cranecams.com/?show=technicalhelp
Old 09-16-2010, 08:16 AM
I would say that cam would work with 9.5:1 smogger iron heads, 9.75:1 with iron vortec heads, and 10:1 with aluminum heads.
I would just use an old school 280H compcam with your set up. 280/280 advertised with 230/230 at 0.050" with 110 lsa. This cam will work with your heads and 10.5:1 cr.
Plus your heads don't need any extra exhaust duration due to a really good intake to exhaust flow ratio. Furthermore, the 280H will have a better chance for a long engine life due to softer lobe ramps.
Old 09-16-2010, 11:57 AM
Wiki Edits: 326
Thanks for the input F-BIRD. I'm always interested in learning from some of you other guys.
Old 09-16-2010, 12:28 PM
My heads are 64cc so if I run a dished piston of the appropriate dish to achieve 10:1 and run the 4x4 270 cam and 93 octane I should be fine? The 270 according to desktop dyno shows a strong torque curve I like.
Old 09-16-2010, 04:19 PM
Johan Lokander's Avatar
10.5:1 SCR
1 3/4" open headers
RPM HP TQ
2000 143 376
2500 190 399
3000 243 426
3500 307 460
4000 372 488
4500 431 503
5000 485 510
5500 516 493
6000 530 464
6500 527 426
7000 512 384
Have I missed somthing?Dident Crane get out of bussnis?
Old 09-16-2010, 04:41 PM
comp cams X4270H
intake lift .48
exhaust lift .498
Run it, I ran a similar cam in a 350 with 10:1 compression. Had no problems with pinging.
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 01:13 AM
Cam Help shsouthard Engine 18 03-29-2009 10:33 PM
Compression Ratio Tribal Engine 3 11-15-2008 08:00 PM
max compression ratio on 89 octane gemini86 Engine 31 07-01-2005 04:35 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
