Cam Confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2010, 09:12 PM
Cam Confusion
I have a 351w and want to bump it up a little, not sure what size cam i should use. the engine is stock and has a stock cam, the intake is a Wieland steath with a 600cfm elderbrock carb. i would like to add a cam that is good on the street and performs on the track as well. not looking to turn 10's in the quarter but at least burn the tires a little. Oh the engine is mid 70's, and in a 90' mustang with a 5 speed.
Old 09-13-2010, 09:21 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Stock heads I assume? most fords will benefit from a dual pattern cam, that is to say that the lift and duration are higher on the exhaust side. Headers are one very good adder here as well. What is the rear end gear ratio? There are many factors in cam selection, many here can add way more than I on this subject but thats my 2 cents for now cheers.
Old 09-14-2010, 06:01 PM
The problem with more cam is lack of compression, these two walk together. The cam should be somewhere around the equivalent of a Comp 268 to 272 for the street. with a cast iron head the compression should come up around 9 to 9.2 with your stock heads. With GT40 iron heads off an Explorer you can push that to 9.5.
Bogie
Old 09-14-2010, 08:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I do not know if a "mid-70's" 351W will qualify- but there were Ford engines made during the smog era, that were saddled w/timing sets (both OEM and OEM-type replacement) that retarded the cam timing.
Some were a significant amount- on the order of 8. So if your engines has this type timing set, change it to a good aftermarket timing set, w/o the cam retarded. This will help regardless of what cam you choose to run.
Old 09-14-2010, 08:26 PM
techinspector1's Avatar
Wiki Edits: 326
The 429/460 was the worst. We used to order chain sets for a '68-'71 429 to get the correct pieces. Of course, if you're degreeing the cam like you're supposed to, then you will catch this stuff.
Old 09-14-2010, 09:38 PM
Cam confusion
I was looking at a comp cam thumper kit 268/272,comes with new timing set and lifters, springs. wanted to make sure that was what most would use in my shoes, as far as lift goes i should stay under .500 right?
Old 09-14-2010, 09:40 PM
I do have headers (BBK), and the rear is stock not sure yet on ratio but will check
Old 09-14-2010, 09:57 PM
Dirty Biker's Avatar
Bold As Love
Did you try a free trial of engine analyzer pro 3.9 yet? Punch in the data and see for yourself what it has to offer in the way of tuner suggestion. It is fun imo!
Old 09-15-2010, 11:01 PM
thanks
fun program...
Vacuum reading with new cam sbc 350 eric32 Engine 17 09-05-2010 06:37 PM
Cam tight on insertion 70bird Engine 12 12-27-2008 08:51 PM
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 11:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 11:17 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 12:03 PM
