Cam confusion??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 11:06 AM
riflegunbuilder's Avatar
Cam confusion???
I am running a 67-68 327 in a 55 BelAir. Muncie M20, 3:55 rear end. I am going to change to a Holley Street Dominator 300-36 intake, and Elec. Ign. .
I am trying to decide on a cam. My choices are:Comp 12-670-4 There take on a 300 horse 327 cam. An Isky 264 cam, or a Lunati 00017. Two of these seem a good deal bigger than the other. I am looking for a driver, I just want a little loapy sound and would like to pick up 20-25 HP out of the whole cam intake deal. I don't want the thing to fall flat every time I leave a red light. Opinions please.
Old 09-19-2005, 11:47 AM
DoubleVision's Avatar
I`d use the comp 268H, it has 218 duration @ .050, lift is .454, it has a slight lopey idle, but still has good low end torque for daily drivers and can be used with a stock converter.
Old 09-19-2005, 04:08 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I'd check this out as a legitimate option. http://www.schneidercams.com/shop.htm
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
cam base circle vs. lobe lift question S10xGN Engine 4 09-19-2004 10:31 AM
Installed New Cam, CAR WONT Start/no Compression? sum87mustang Engine 4 10-27-2003 07:52 AM
289 cam change franklin289 Engine 0 04-22-2003 02:38 PM
