Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Correct Variable Cam Timing
Old 07-29-2009, 07:33 AM
ap72 ap72 is offline
Banned
I talked with the guy that designed it- I wouldn't run it. It kind of does do what it says it does, but it only does under engine acceleration AND it messes with your ignition timing. If I was running a crank trigger ignition and a good FI system it may be worth looking into but WAY too hard to tune with a dizzy and a carb.
