Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Correct Variable Cam Timing
Old 07-29-2009, 05:42 PM
sam-missle sam-missle is offline
Originally Posted by ap72
I talked with the guy that designed it- I wouldn't run it. It kind of does do what it says it does, but it only does under engine acceleration AND it messes with your ignition timing. If I was running a crank trigger ignition and a good FI system it may be worth looking into but WAY too hard to tune with a dizzy and a carb.
Please explian how this item (messes with ignition timing).
sam-missle
