Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Correct Variable Cam Timing
Old 07-29-2009, 06:49 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by sam-missle
Please explian how this item (messes with ignition timing).
sam-missle
If you mess with the cam timing, you mess with the ignition timing too, in relation to the position of the piston in the bore relative to TDC. They are connected by gear mesh at the rear of the cam. Move the first (cam), you moved the second (distributor shaft) too.
