07-30-2009, 07:17 AM
How fast is fast enough?
Originally Posted by ericnova72
If you mess with the cam timing, you mess with the ignition timing too, in relation to the position of the piston in the bore relative to TDC. They are connected by gear mesh at the rear of the cam. Move the first (cam), you moved the second (distributor shaft) too.
gracias! ..
