Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Correct Variable Cam Timing
Old 07-31-2009, 06:10 AM
ap72 ap72 is online now
How fast is fast enough?
Originally Posted by ericnova72
We are discussing moving (variable) cam timing in a RUNNING SBC engine by way of a chain tensioning device. If the tensioner advances the cam, this will advance the ignition timing too because they are geared together. Unless you have an idea for a variable distributor housing positioner that will counteract the variable timing chain tensioner, the timing IS going to change.
Because having two moving parts where there used to be none is always a good idea.
The best thing I can think to use to get around it is just going with crank fired ignition.
