cam timing
Rhodes Hyd lifters did a similar thing. The lifters had a controlled bleed down so at lower rpm the lifters would bleed down giving less duration and lift and at higher rpm less bleed down time and closer to what the cam grind would do with solid lifters. I had a set years ago and they were noisy like solids at lower rpms.
r
