Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Correct Variable Cam Timing
Old 07-31-2009, 07:34 AM
ap72 ap72 is offline
Banned
Originally Posted by Guy Hiltz
I would think that any difference in cam or ignition timing with this device is going to be very minimal,its a copy of this Comp Cams peice;
http://www.compcams.com/technical/Ca...106-07/320.pdf
The timing chain would have to have an awful lot of stretch in it before there would be an advantage to using this.And to call it a variable valve timing control device seems to be a bit of false advertising,its is a tensioning device,period.And 7-30 hp gain,this isnt even realistic !!! And the parts are affected by wear and need to be checked on a regular basis.Just another case of someone trying to lighten our wallets with an unecessary peice. JMO !!!
Guy
Its not a guy tryiong to pawn off snake oil- it actaully does work, its just that like most first steps it has a lot of flaws and needs refining. Not a bad idea, just hard to implement effectively. I could see 30hp on a big block given the right parameters.
