Cam/Crank TDC question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2011, 12:36 PM
david-b's Avatar
Dave is THAT guy
Since the weather is getting warmer, time to start working on the Monte Carlo. Last season ended with the motor being in the car, but not being to start. She would backfire through the intake. Then she had to go into storage.
Now she's back out and getting cleaned up and now I can start working on it again. Was told the valves are probably too tight. Distrib was good and played with various timing, all with no luck real luck. Back fire did change from going out the exhaust to coming up through the intake.
My question is, when I was looking at pics of when I assembled the engine, I had the crank at TDC, and the cam looks like I had it at the 12 o'clock position. Looking at pics, people have the cam at 6. When I was doing the valve adjustment, the intake/exhaust lifters all move properly and at the right time. I did the test with the air coming out of cyl 1 spark plug and it blows plenty of air out.
So should I second guess myself or does that sound right? Thanks
EDIT: On a SBC 400
Old 04-04-2011, 01:00 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...valves_SBC_BBC
Old 04-04-2011, 01:05 PM
david-b's Avatar
Dave is THAT guy
Originally Posted by techinspector1
I'm going to try to readjust the valves again, but wanted to make sure that the cam sounds like it's in place properly first before I waste more time doing something that won't make a change. Guess she is good to go minus the valves then. Thanks
another question about a 305 crank Casperdude898 Hotrodding Basics 1 03-17-2008 05:06 PM
BBC Crank Question inquiring_mind2 Engine 2 11-10-2007 09:18 AM
Crank Question CHEVYPOWER/355 Engine 2 10-29-2007 12:33 PM
Crank question! ap72 Engine 3 01-08-2006 09:02 AM
sbc crank question 79 Malibu327 Engine 6 02-15-2004 09:10 AM
