Cam and Cranshaft sensor issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2004, 04:27 PM
I am having another cam and cranshaft issure. I just replaced the coil pack computer (dont remember then name but where the spark plug wires go to the plugs) and since then I had not had this porblem. This was about 9 months a go. Before replacing it I used to get that same error over and over again, then I pelcaed and it went away. But now today it came up again. I dont know what I should do. Any suggestions??? Should I replace the sensores??? Is that easy?? Or maybe could it be bad spark plugs and wires causing this problem. Its a 1992 transport pontiac 3.8 GT and its code error 18. Any suggestions would be wonderfull Thanks for you time guys.
Old 09-19-2004, 02:47 AM
this is odd
it sounds like a grounding problem to me. as for the sensor likely not easy to change
