Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cam degree
Thread: cam degree
Old 08-31-2010, 01:08 PM
engineczar's Avatar
engineczar engineczar is offline
Originally Posted by zoomo
So from what im reading you basically just want the number one cylinder intake vaqlve all the way open when number one is at tdc?
No
You have to look at the cam card that was supplied with the cam or go to the Comp website and plug in the grind number to get the correct numbers.
That cam will probably have a setup with the intake fully open at about 106 degrees ATDC.
BSE Racing Engines
