Cam Degree with heads off
I picked up a short block 383. Last night I got a set of heads 3973487. The block was decked and the guy last night told me the heads were also decked. Its clear, if the heads were done it was a while ago. There are brand new 2.08/1.60 SI Portflow S/S valves (+100) and springs installed. I just got a Summit G1056 Degree kit off Craigslist. I printed off the instructions but they are for if the heads are installed. I want to check the valve to piston clearance with the heads off so I dont screw anything up. Does anyone know how with that kit? Also if anyone is in Temecula and wants to teach me how to use it properly, come on over!
I have a Scat crank, not sure what pistons, Comp Cams roller rockers, LSM cam, Team G manifold and a Holley 750 to top off this build. I also have Jegs 1.6 rollers to install on the heads. The heads have pressed in studs (with a tack weld), and no guide plates. Do I need guide plates or anyhting wlse to run these rockers? Possibly a dumber question, but when I read the articles of these guys swapping heads and manifolds for Dyno runs, are they putting on new gaskets every time? I assume they get torqued down each time, so I think they would get a different reading ( P2V clearance) each time. |
Thanks
Just curious, how do I know what length pushrods to get? I have the tool, but again wasn't sure about the whole torqued down thing. If I get the rocker studs pulled and drilled/tapped, when I put in screw-in studs, should I get guideplates? |
Rocker tip sweep across the valve tip will determine pushrod length. Set up the valvetrain on one cylinder using light checking springs, take a black marker and color the tip of the valve so the roller wheel will leave a track mark, then cycle the valvetrain through a couple rotations. You want to set pushrod length for the smallest pattern on the valve tip.
I would have guideplates installed when the studs are done. |
Here's the tutorial from CompCams concerning pushrod length....
http://www.compcams.com/Products/CC-'Pushrods'-0.aspx I can't seem to get this to work as a link, so copy and paste it into the address bar.... |
Awesome. I can't get the pushrod tool into the spot to measure the distance. I have some that say 8.400 3006 that came with the motor. They barely fit in the hole in the head but are way too long.
8.400" will be too long for any 23° head on a standard deck height SBC. Will usually be somewhere between 7.800"(stock length) and 8.100" depending on lifters cup position in the lifter body and length of valvestem(std, +.100" or +.200").
| Summit cam for stock heads | Johnabie | Engine | 2 | 06-12-2009 09:47 AM |
| Cold Lash Adjustment on Vortec Heads w/Solid Cam? | ezobens | Engine | 8 | 04-30-2007 01:03 PM |
| Vortec heads w/solid lift cam...anyone? | rbomar | Engine | 6 | 08-25-2006 04:42 PM |
| Stock Heads & Comp Cam 286H | bccsrc | Engine | 11 | 08-21-2006 02:55 PM |
| 383-- use the vortec heads? what cam? | slonova | Engine | 10 | 02-02-2004 11:45 AM |
