Cam Degree Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2006, 06:08 AM
Cam Degree Question
Last night I was checking the cam I put in my 351W. I was checking the location of the intake centerline. I found TDC by going to zero on a dial indicator on the piston and going down .050 and the other way .050 and then splitting the difference on the degree wheel. Is this accurate enough?
The cam says to install at 107 deg intake centerline. I got 108.5 deg. So, I tried to advance tha cam 4 deg, because that is the interval in my timing chain, and I got 101 degrees. Is it that the timing chain markings are that far off, or am I doing something wrong?
Old 07-27-2006, 06:29 AM
DaSouthWon's Avatar
I put up the tools against$300
should be pretty close. The way I do it is by bolting a flat piece of steel stock across the top of the cylinder. The piece of steel has a bolt tapped in to it. I turn the piston clockwise and mark it on the degree wheel, then I turn it counter clockwise and mark that. divide the number of degrees in half and mark that on the wheel. take the steel stock off and rotate the crank to the middle mark on the degree wheel. That should be TDC
Old 07-30-2006, 06:55 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
NO. Something is wrong. Do what he suggested.
Cheapo junk timing set?
What do the computer guys say? GIGO
I always say,
Never skimp on the valve train, it is the blood vessels to the heart of the engine.
www.readershotrods.com
Cam Question shunt7706 Engine 1 10-27-2005 10:04 PM
Cam Question TonyMac Engine 7 09-23-2005 12:31 PM
goodwrench crate motor/ cam question 72chevy240z Engine 25 04-07-2004 07:14 AM
1987 dodge 318 cam question 74huggerorange Engine 5 12-21-2003 09:54 AM
Cam question Jare Engine 3 11-27-2002 03:18 AM
