Cam Degreed On Sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2006, 08:53 PM
Cam Degreed On Sbc
how hard is it to degree cam on a 1970 LT-1 370 hp mech cam and what do i
need to due this task, also time to do labor. is there a simple way to adjust valve lash procedure. i am using a COMP CAM mech. .520 intake x .540 exhaust lift.
any help
TIM
Old 06-22-2006, 09:27 PM
You will need a dial indicator and a degree wheel and a lot of learning about camshaft timing procedures before you attempt a task of this nature. This job can be rather complicated for the novice wrench and there are areas where if you make the slightest mistake, you coluld bend your valves, pushrods, or worst case scenario, pistons and cylinder block.
I suggest studying the data card that comes with your cam and the installation instructions very carefully then, and only then, if you are comfortable with your new knowledge, by all means, degree that camshaft!!!
Time to do the job the first time: priceless.
400 SBC...New CAM thecamaroguy Engine 41 03-15-2005 06:47 AM
ZZ3/4 cam into pre 87 SBC? RX7Jeff Engine 2 03-06-2005 07:07 PM
sbc cam install al37ford Engine 3 02-19-2005 12:25 PM
350 sbc cam suggestions please sfd771 Engine 1 07-30-2004 06:25 PM
327 sbc w/350 hp cam overheats/stalls pircjo Engine 10 05-11-2003 07:18 AM
