Cam duration vs. Cam lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 09:29 AM
Hey! just wondering on the effects of a high lift cam will have on idel quality, i know more duration will give you the lopey idel, but im looking to upgrade to a cam with around the same duration and more lift.
Old 08-04-2010, 09:47 AM
more lift lets in more air and makes more power.
more lift doesn't effect idle quality.
However, more lift can effect valve train durability. More lift equals more stress on the lobe, lifter, rocker-arms, and springs.
also, depending on how much lift, you need to be concerned with piston clearance, spring stacking, and retainer to seal clearance.
Old 08-04-2010, 12:16 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Increased lift from say a 1.5 rocker to a 1.6 will effect duration, how much this has an effect on idle characteristics is anyones guess but there will be some influence on the effective duration. Changing the cam is changing the cam so all other factors such as ramp rate, lobe sep etc etc is in play which may change the idle lope, finding a cam with everything exactly the same as the next except for lift? maybe,,,maybe not out there
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
Vortec heads w/solid lift cam...anyone? rbomar Engine 6 08-25-2006 04:42 PM
Cam lift and duration? BMM Hotrodding Basics 1 07-23-2006 12:55 PM
cam info aceofspades49c Engine 1 03-30-2006 11:23 PM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 02:42 PM
