Looky here
Dynamic CR and Cam
Hey RippinRon thanks
So it was suggest to me from a reptiable speed shop in the area that I would be happy with a 280H Compcam for my 4 bolt, 454 .030" with closed chamber heads 101cc chambers milled to 97cc chambers with flat top pistons. The dur at .050" is 224, the dur advertised is 280. The 2 different numbers DO CHANGE the dynamic CR. http://www.projectpontiac.com/ppsite...nt/view/16/30/ On the site above is the Pontiac CR calc table. If a guy plugs is the chev 454 specs and uses 224 duration hit calculate at the bottom watch the dynamic CR, then type in 280 duration and go to bottom again hit calc and watch the dynamic change. The result is 224 make it higher than 280. So which should a guy go for?? Thank you |
dynamic CR vs Static CR
Hey RippinRon..thanks for the reply and no-how
My engine specs are: 4.28" bore (which is .030" I believe) 4.0" stroke 6.135" rod length .022" steel shim gasket .040" deck height 97cc Combustion chambers 4.9cc valve reliefs in piston (2 of them) I am not getting the CR you said. I am down around 9.09-9.14 CR ???? http://www.rbracing-rsr.com/compstaticcalc.html that is if you use the site above, if you use the Pontiac site the duration is the only other variable. The responce you sent did not have a link to any site. Thanks |
I was guessing on some things. Look at the bottom of this page for the download http://www.empirenet.com/pkelley2/DynamicCR.html. You definitely want to keep you quench or squish as its sometimes called (deck clearance + head gasket thickness) between .035" - .044". This improves fuel/air mixing via turbulence and improves detonation resistance.
CR/DCR vs Duration
Hey Ron,
I cannot download the link...I work for a place that you need IT clearance. Anyway, my deck clearance is .040" already and with a .040" gasket your looking at .080" and with a .022" gasket your looking at .062" which with even 97cc heads (which is good for high CR) creates a not too positive CR for a good engine. That 280H Comp is going to make this thing fall right on it's face I think. Unless I am way off on CR calc. You have the numbers that I have. |
Having a quench of .062" with say 9:1 will make it worse in the detonation department than having a .040" quench and 9.6:1. I'm saying you should have the block decked to maintain proper quench. What pistons did you use? I'm guessing jobber type with .020 reduced compression height which isn't too good.
deck clearance..quench??
yeah is doesn't sound good from what your saying.
This is a REMANF straight from AC DELCO and the clearance from wrist pin to dome is as you say jobber?? I didn't do the engine I picked it up pretty cheap with only 40K on her and wanted to just beef it up some. She is already sitting in my 65 Malibu waiting for my valve job/milling to get done. Darn-it I was thinking through my calcs with .040" deck and .022" gasket with 97cc heads, 4.9 reliefs that I would be in the low 9.0's on CR. Did you look at the CR calc though? it says roughly 9.14 or so. Now I am back pedaling if what you say is true. It contradicts what others have said...slightly |
A quick and dirty free calculator is here http://www.kb-silvolite.com/calc.php?action=comp. Bogie |
Okay deck clearance is from the flat part on top of the piston to the deck of the block at top dead center. Compression height is from the center of the wrist pin to the flat part on top of the piston. Here are some good calculators http://kb-silvolite.com/calc.php. But I don't use their dynamic compression calculator. The block should have been decked some to square it up if not i'd start to wonder. Regardless you need to maintain proper quench. Be it replacing the pistons with ones with a higher compression height or decking the block .02" to go with .022" head gaskets. Read up on quench on google or http://kb-silvolite.com/article.php?action=read&A_id=35.
| Understanding Cam Specs a bit more. | Lloyd1wv | Engine | 5 | 01-11-2008 02:06 AM |
| Having a hard time with cam choice | blacksunshine | Hotrodding Basics | 12 | 02-14-2007 11:21 AM |
| cam talk | roy383ci | Engine | 18 | 04-30-2005 07:40 AM |
| 305 cam carb manifold | stickshift | Engine | 6 | 04-12-2005 03:46 PM |
| Cam Choice with CR of only 8.4:1 | meschnebly | Engine | 14 | 07-07-2003 01:46 AM |
