Cam Dynamics Catalog - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2007, 04:31 PM
F-BIRD'88's Avatar
Yada Yada Yada
Does any one happen to have a old Cam Dynamics catalog handy?
Old 06-29-2007, 05:48 PM
Hippie's Avatar
Last journal entry: HEI comparison.
1983 Edition work for you?
Old 06-29-2007, 05:52 PM
F-BIRD'88's Avatar
Yada Yada Yada
Ya , what is the Cam dynamics part number for Small block Chevy solid lifters?
Old 06-29-2007, 06:00 PM
Hippie's Avatar
PN is 1800
Old 06-29-2007, 06:08 PM
F-BIRD'88's Avatar
Yada Yada Yada
Tanks
Old 07-06-2008, 10:32 AM
Cam Dynamics Cam
I have a 130042 CD / 35-25-99 / 81488C Cam Dynamics cam that I took out of my 1972 Ford 302. What I need is the specs on this cam so that I get a new cam. these are all the numbers on the cam. I have no idea what they mean maybe you can gelp me out.
Old 07-06-2008, 04:49 PM
F-BIRD'88's Avatar
Yada Yada Yada
measure the lobe lift using a dial caliper.
its likely this cam
Crane cams bought out Cam Dynamics. For a while the "Energizer" line of cams retained the Cam Dynamics brand name.
Old 07-06-2008, 09:36 PM
Stroke Meister
130042 CD
So maybe that 'CD' after the part number signifies Cam Dynamics...
Old 01-27-2009, 05:34 PM
I have a sbc camshaft. It appears to be a Cam Dynamics cam from what I have found. The part # is CD10007B. Can anyone help me find out the specs on this grind? The date on the back is 11-01-03
Thanks
Old 01-27-2009, 05:56 PM
F-BIRD'88's Avatar
Yada Yada Yada
It may be this cam.
http://www.cranecams.com/?show=brows...07&lvl=2&prt=5
Cam Dynamics was bought out by Crane Cams so you could email them to get info on that cam.
Old 01-27-2009, 06:33 PM
Thanks, I'll try emailing them, but before I do that I suppose I'll throw it in a block and find out the specs.
Old 01-27-2009, 10:17 PM
Crane also has all the CD master lobes and tooling, and can still supply all the original CD grinds if you are partial to them instead of Crane or any other brand....
Old 01-28-2009, 07:58 AM
racecar100's Avatar
I do have every issue on Cam Dynamic Cataloge. Even still the first copy that came out.
Old 01-28-2009, 10:23 AM
Originally Posted by F-BIRD'88
It may be this cam.
That was the cam, thanks F-Bird!!
Old 07-21-2009, 09:59 AM
BBC solid roller
I'm working on a BBC 427 thats been setting in a rail for years. I'm down to the cam and it looks like a cam dynamics. The front of the cam reads CD- 318-325 08-F167. If anyone can help with lifter adj.etc. Thank you for your time.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Degreed the Cam -- 40 Degrees Advanced!!! JohnTN Engine 32 03-22-2006 10:40 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
cam selection chevyelc81 Engine 9 09-17-2002 06:41 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
