Cam endplay/which cover? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2007, 03:46 PM
So I have a 1989 chevy 350 block that I'm building for performance. I got a comp cams 08-423-8 hydraulic roller camshaft. I'm reusing my stock lifters. How am I supposed to drive the crank gear on? I used a rubber mallet to hit a piece of wood and went around the gear and tapped until it looked like it was all the way on, but how do I know that it is all the way on? Also, I need to order a timing chain cover. What kind should I get that doesn't cost money, but looks good enough, with a chrome finish? And what do I do the check camshaft endplay? Thanks for you help.
Old 10-18-2007, 04:31 PM
And also, what should I get for a harmonic balancer?
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
What cam specs work well with centrifugal Superchargers? hotrodf1 Engine 2 09-22-2007 04:21 PM
350 build upgrade cam suggesstions. azbandit Engine 2 02-07-2005 06:23 PM
Comp cams took care of failing cam TurboS10 Hotrodders' Lounge 12 01-08-2005 07:15 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
