Cam explanations. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2007, 03:56 PM
On the learning curve.
Cam explanations.
Ok Im looking for some cam info. You guys seem like an intelligent bunch to come too lol. Anyways Im working on the desktop dyno down near the bottom for the cam it says IVO {BTDC}, IVC {ABDC}, EVO {BBDC}and EVC {ATDC}. What do these mean? Are they part of the cam lobes? Lobe separation? Cams are mildly confusing lol. Right now I only really understand lift, duration and lsa. But I dont really even understand those, I can only squeeze by. Any help on this topic or maybe some reading materiel would be appreciated. In the meantime Ill be googling lol.
Thanks Steve
Old 05-18-2007, 04:21 PM
Thanks Steve
IVO is Intake Valve Open in degrees Before Top Dead Center (BTDC). This of course is an assumption that the cam you're using opens the intake before top center, many emissions grinds open the intake valve After Top Dead Center.
IVC is Intake Valve Close in degrees After Bottom Dead Center (ABDC).
EVO is Exhaust Valve Open in degrees Before Bottom Dead Center (BBDC).
EVC is Exhaust Valve Closed in degrees After Top Dead Center (ATDC). A couple notes; the degrees ATDC added to the degrees of the intake opening (BTDC) are the degrees of overlap. The other note is that again with emissions compliant cams the exhaust valve may close before TDC.
Bogie
Old 05-18-2007, 04:30 PM
Ok that was exactly the info I was looking for! Thanks! So if I understand this correctly these numbers would determine the profile of the cam lobes? So Im assumeing that if I were to send lsa, lift, IVO, IVC, EVO and EVC all too comp cams or some company of the like they could have a cam custom ground for me with all of those factors that I specified?
Thanks Steve
Old 05-18-2007, 04:34 PM
You bet they could.
Bogie
Old 05-18-2007, 04:36 PM
Well oldbogie, I appreciate the help. Im off to continue working on my engine design!
Thanks Steve
hmmm... I wonder if I could try and gring my own cam for my 305?? lol.
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
