cam gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2009, 03:48 PM
cam gear
hello, names mike.
I use my friends 1998 dodge truck. I have a ski boat I use for more then skiing. fishing mostly. is there anyone who knows anything that might help me with my problem?
Old 08-02-2009, 03:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by harleywings
hello, names mike.
Well, there's the cash for clunkers that will give you a rebate on your old car, so you can buy yourself a new truck. It will have cam gears, too.
Old 08-02-2009, 04:57 PM
You forgot to say what your problem is.
Old 08-02-2009, 10:22 PM
cam gear
hello, names mike.
Here is my problem. I was putting in a water pump and got one of the long bolts in one of the bottom short bolt which goes all the way in to the cam gear.( first off this is a stupid design) Before i knew what happened I hear a clicking noise I pulled the water pump out and realized what I did so I put it in the right hole but had already created my next problem. after it was all put together I tried to start it with no luck. I right away new what had happend but I thought it hit the chain, but in fact it broke my cam gear. so I get a new one and replaced it after i made sure that the mark and the keyway was exactly the same. I put it all back together and it still wont run. It backfires thru the carb and thats about it. why won't it just run all I did was pull out the cam gear and replace with the timming mark set. The cam gear facing down and the crank gear facing up both facing together and I even tried to move one way or the other with no luck either. Why should I have to mess with the distributor when it wasn't moved at all only the front of the motor. is it posable that a valve hit the piston? I figured thats old school that the motors are not like that anymore? please help me. what to do next?
Old 08-02-2009, 11:57 PM
techinspector1's Avatar
Wiki Edits: 326
Copied and pasted from www.justanswer.com...........Not sure if this will address your problem though.....
I have a 1998 dodge ram 1500 with the 5.2 engine. I put a new engine in it and it would idle for about 30 seconds and start surging. I though it was a vacuum leak at the intake so I change all the gaskets on the intake. I checked the vacuum and it was reading about 20 when the engine started surging the vacuum fluctuated. I then checked all the sensors and replaced the IAC,and the crankshaft sensor. I put in new cap,rotor,wires, and coil. I took it in to be checked. It will run if the idle is above 1500 rpms. I was told when they tried to check the timing with the computer it kick them out. I did get two codes with the scan tool. The codes are 1391 and 1492. I did not know if I got the flex plate correct so I pulled the engine and started back at step one. I pulled number one plug and rechecked the timing. With number one up the crankshaft pulley line up at 0 on the mark the flex plate is not lined up with the opening. Lining it up it is about 5 degrees before tdc. Please Help.
Accepted Answer
Hi. You need to index the distributor. Injector synchronization is set by turning the distributor, and if the distributor is off far enough it will send spark to the wrong pole in the distributor cap. Ignition timing is controlled by the engine controller, so there is no way to set timing. Once the distributor is indexed the controller takes care of the timing. Here is the procedure.
Connect a voltmeter to the distributor sensor connector by removing the end seal and carefully back probing the connector. Connect the positive lead to the sensor output pin (pin 3, either a tan wire with a yellow tracer or a gray wire, depending on vehicle application). Connect the negative lead to the sensor ground pin (pin 2, a black wire with a light blue tracer).
Rotate the engine clockwise as viewed from the front, until the number one piston is at Top Dead Center (TDC) of the compression stroke. The timing mark on the vibration damper should line up with the zero degree (TDC) mark on the timing chain case cover.
Continue to rotate the engine slowly clockwise until the V6 or V8 mark (depending on engine type) lines up with the zero degree (TDC) mark on the timing chain case cover. The V8 mark is 17.5 after TDC and the V6 mark is 14.7 after TDC.
NOTE: DO NOT ROTATE THE ENGINE COUNTER CLOCKWISE. IF THE ENGINE IS ROTATED BEYOND THE MARK, RETURN TO STEP 2 AND REPEAT THE PROCEDURE.
Loosen the distributor clamp bolt.
With the ignition switch in the ON position, rotate the distributor slightly in either direction until the voltmeter switches between the sensor transition point of 0 and 5 volts.
Adjust the distributor as close as possible to either side of this transition point and tighten the distributor clamp bolt to 170-230 in. lbs. (19-26 Nm).
Read more: http://www.justanswer.com/questions/...#ixzz0N629v3AP
Old 08-03-2009, 08:13 AM
cam gear
thank you tech guy, I didn't move any of that so I figured it should still be alright. I will let you know how it goes. and thanks again.
Old 08-03-2009, 10:28 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
I just heard on the news a few days ago that the government ran out of money for the "cash for clunkers" program. So it is no more. They ran out of funds within the first 3 days.
Just thought I'd inform everyone.
Old 08-03-2009, 03:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The House found another Big-A $ pile, congress has to pass it, though.
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 09:39 PM
Cam install questions? TheBigDeal Engine 21 04-22-2008 08:58 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Gear drives on roller cam nostalgicnova Engine 3 02-01-2005 10:25 AM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
