cam going to be ok - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2003, 07:37 PM
cam going to be ok
I have a 350 built with 441 heads rebuilt with dish piston's. edelbrock intake Idle to 5,500 with 600 carb with 480 lift 230 duration cam. will this combo be ok
Old 07-06-2003, 08:15 PM
head gasket's are 0.50 thick. with high volume oil pump700r4 2400 stall with 3.73rear.accel distorber. hope some one can help.
Old 07-07-2003, 02:06 AM
I did a 350 w/441's & stock dished pistons & a 224* cam & it didn't run too strong. Too much cam for compression in the low 8's.
