We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-22-2002, 05:05 PM
stfinney's Avatar
stfinney stfinney is offline
Question cam grind with 991 heads
What would be a good cam grind to use with 991 heads(76cc, 1.72/1.50 valves) and a .015 head gasket on a 350 SBC. I have a 278 duration cam with 222 @ 50 and a lift of .467 and a 110 lobe spearation. Would this cam work ok??
Old 11-22-2002, 06:54 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
this would work but you are really limited by the small intake valve, i got your e-mail and will get you a list of what i have available, as soon as i can do my inventory, maybe next week, bob
Old 11-22-2002, 07:02 PM
stfinney's Avatar
Post
I was thinking of changing to a 250/258 duration, 205/214 @ 50, .432/.453, 111 lobe separation. Would this be a better cam?
Old 11-22-2002, 07:14 PM
Post
yes much better for the 2-bbl heads,1.72-1.50
Old 11-22-2002, 07:26 PM
stfinney's Avatar
Post
[ November 22, 2002: Message edited by: stfinney ]</p>
Old 11-22-2002, 07:32 PM
stfinney's Avatar
Post
When using the 305 heads on a 350, is it just a bolt on and go, or is there anything special that has to be done to the heads or block? Also, what would be a good Intake and Carb suggestion? I already have a dual plane Weiand intake and an Edelbrock 600cfm carb. Would these work ok?
Thanks!!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
