Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam grind numbers
Old 02-12-2013, 12:06 PM
JeffB's Avatar
JeffB JeffB is offline
With the cost of aftermarket heads available you are wasting your time and money fooling with a stock head.The budget you have to work with will take some smart shopping for parts,the cam you have would produce some good low end and mid-range power but you should go for a 350 build as those parts are more budget friendly.
