Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam grind numbers
Old 02-12-2013, 12:11 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by JeffB View Post
With the cost of aftermarket heads available you are wasting your time and money fooling with a stock head.The budget you have to work with will take some smart shopping for parts,the cam you have would produce some good low end and mid-range power but you should go for a 350 build as those parts are more budget friendly.
In other words you don't know how to hot rod a 305.
