Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam grind numbers
Old 02-12-2013, 12:27 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
305 Vs 350,which is better
Originally Posted by JeffB View Post
With the cost of aftermarket heads available you are wasting your time and money fooling with a stock head.The budget you have to work with will take some smart shopping for parts,the cam you have would produce some good low end and mid-range power but you should go for a 350 build as those parts are more budget friendly.
auto wrecker 350s are cheap too.
either engine will work. look around for a deal.If you want dirt cheap,dont care how long it lasts,moderate power,
buy a complete running car from a wreck. take out engine,(pick a car that has a roller motor)regasket/clean/replace timing chain,buy a cheap cam,use FBs back yard porting method,drive a car that performs as it is built.
enjoy,,,
