cam and heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2003, 12:04 PM
New Member
cam and heads?
Can anyone recomend a kick butt matching head a cam and what intake to use for a older 302 block with a 347 stroker kit. I'm pushing for 375- 400 horse. I was thinking maybe the trick flow twisted heads. What do you guys think? And also what would you recomend for tracton to get a good hook-up? It's going in a ford falcon 64
Old 12-10-2003, 02:11 PM
firestone's Avatar
http://teamrfc.gospelcom.net
AFR CNC ported 285cc heads would be your best bet. I would go with something along the lines of a Comp Cams 294H cam (244 244 @.050 .518 .518 lift) This with a good intake (performer RPM or victor JR) would easily get you at least 400 hp, probably closer to 450.
Adam
look at AFRs dyno tested motors:
http://www.airflowresearch.com/dyno/ford_dyno.htm
Old 12-10-2003, 02:40 PM
mstngjoe's Avatar
I think you mean the AFR 185 heads....
Old 12-10-2003, 05:29 PM
firestone's Avatar
Your are right, my mistake.
You are right about the 185cc, not 285.
Old 12-10-2003, 05:59 PM
lluciano77's Avatar
285ccs. Man, those wouldn't start working untill 12,000 RPMs.
That cam mentioned above is awful small if your looking for a lot of hp. Remeber they were using the Cleveland style head on a 302. That was the stock Boss 302. Small block Fords like more airflow.
Old 12-10-2003, 07:34 PM
mstngjoe's Avatar
Regardless of which head you decide on (I'm partial to the AFR stuff), if you are building a serious high performance engine, I would consider getting a custom ground cam. There are a few guys around who do VERY good custom spec's designed specifically for your individual application.
I had Buddy Rawls spec mine and I wouldn't hesitate to use him again or to recommend his services.
Here's his web page: http://www.wighat.com/fcr3/camtruth.htm
Another guy with a big rep is Ed Curtis of Flow Tech Induction.
Something to think about, if you want optimum performance of whatever you put together.
Have a plan and have fun!
