Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cam and heads and valve spring mismatch.
Old 02-28-2013, 10:50 PM
s-10again! s-10again! is offline
also some more questions, the engine i am building is from a boat, steel crank nickel block etc etc...the crank is 2 peice main seal. its going to be hitching to a 700R4 that had a 1 piece is that going to be problem? the 1 piece crank has fine thread bolts and the crank im using (2 piece) has 3/8 studs sticking out of the crank weight.
