cam help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 11:11 PM
chevy350cutlass's Avatar
cam help
ok dont know what cam to go with here what they are Edelbrock Performer-Plus Advertised Duration 278/ 288, Lift .420/ .442, Edelbrock Performer RPM Advertised Duration 308/ 318, Lift .488/ .510, and COMP Cams Advertised Duration 268/280, Lift .477/.480 this is for a street car with c/r of 9.5 or 10 to 1 not sure about that yet more like 9.5 intake will be a Edelbrock Performer RPM and the carb is a Edelborck 750 with a stock 406 bottom end
Old 11-01-2008, 11:24 PM
85 g-body cutlass 2000 stall th400 trans for now 2.73 gears butt will be putting 4.10 gears in
Old 11-02-2008, 04:52 PM
would like more info about these cams that i have picked out and i dont want to go any bigger the what i got
Old 11-02-2008, 08:34 PM
In a 406 ci w. 9.5:1, I would have no problems whatsoever running that larger Edelbrock cam. Especially with a 4.10. I would have a problem with it if you had stock 400 heads.
If you do have stock heads, go with the Comp Xtreme 268. I had one in my 327 with 9:1, 462 heads and a 3.23 in my 67 chevelle. Didn't exactly burn the tires off the car but it ran fine (stock converter too).
If you are looking for the exact same cam for probably a 1/3 of the price, go to enginekits.com or competitionproducts.com, they have a similar Elgin cam and lifters for $89. Elgin is America made. Just look for the same lift figures.
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
