cam help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 04:02 PM
cam help
i have a stock 350 that i would like to put a cam that has a noticeable lope with just putting carb,intake,headers and stall converter.My goal is to be streetable and not mess with the block and heads,i guess what i am saying is i would like more sound with some performance.I have a 383 that is built for performance already. Any recommendations would be helpful.NO thumper cams please.
Old 09-11-2011, 04:10 PM
DoubleVision's Avatar
You won`t find many here that recommend a thumper. Those are fad cams, all bark, no bite.
The cam I recommend is the Comp Cams High Energy line, The 268H.
It works with stock engines with lower compression ratios and gives it a nice idle.
Old 09-11-2011, 05:48 PM
mud.man.rj's Avatar
I agree the 268 is anice all around cam, great for lower compression and works good on trucks and cars.
Old 09-12-2011, 01:30 AM
JeffB's Avatar
Since you don't want to mess with the heads you should stay under .460 lift with stock springs and rockers this would be a good cam selection :http://www.kmjent.com/cart/product.p...5&bestseller=Y the 108 ls will make the idle a little meaner, I would also degree it in at 2 degrees advanced.A Weiand Stealth intake should partner up good with it.
