Cam Help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-04-2012, 06:55 PM
JasonL's Avatar
Thanks
Thanks for all the help. I just ordered the Comp Cams 268 HE .454 lift. I think this will keep me right in my powerband and run all my power accesories with no problem. I can always use my 1.6 rockers if I feel I want to, but I think the .454 lift will be plenty with the 492 heads !
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 09:50 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 05:12 PM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 04:33 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 05:28 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 08:28 PM
