cam help
can i get a little help on cam pic i just picked up small truck 355 gears 5speed 350chevy 650 dp air gap intake headers roller tip rockers i think 9.0.1 stock heads with good springsi did not build this truck ? it has 400miles on motor the cam in it now got the bigger is good pic its to big im sure it has the summit k1107 im looking low mid power what do you all think thanks
For a truck you usally want to be all done by 5500. That cams 3000-6500 powerband is not going to work well. But you need to figure the cr so you can get the proper dcr figured out. The large cam may be because of really high compression. |
| The Following User Says Thank You to hcompton For This Useful Post: | ||
ithooks (12-01-2012) | ||
Replace with summit cam #1785 or 1788
and new hyd lifters |
| The Following User Says Thank You to F-BIRD'88 For This Useful Post: | ||
its a91 truck block heads are 882 it runs good on 91 timming is nuts just got it have not looked in it runs good just dont pull good till way up in rpms where im not at much did test sc test was 140 psi and its 94 s10
The 1788 fbird recommended looks good. Should still be good if your close to 9:1 compression. Do you have any problems with knocking and can you run 87 octane now?
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
ithooks (12-02-2012) | ||
it has hei proformance distributor was thinking comp cam 268H with the big cam in how can i get the dcr of engine sc was 140 it will run on 87 if i baby it good i love the bigger cam its just not what the truck needsi do most my driving on street work and back and i like to play just dont what to get my *** left in the dust frome my 3000 to 6500 cam you know sounds bad by the time it get going it to late:mad
United Engine & Machine Co. Incorporated Wait so you put 87 in it and let it get hot and beat on it a little does it knock or ping? If so i bet you have more than 9:1 compression with that big cam it shouldnt knock with 87. Might want to figure the dcr before you buy anything. I got a sinking feeling you will still need a strong cam. |
This is because the cam timing effects the gauge pressure reading. If the valves were closed at BDC and you got 140 psi, the approximate SCR would be about 8.5:1. But if the cam is radical, you're looking at more SCR than that. Do us (or should I say ME) a favor and use punctuation, or at least periods. The sentences all run together and it's hard for me to read what you're saying. Thanks. |
It just pings sorry i dont use key pads. Guess i can pull the heads and take a look at pistons and heads cc more than i like to do this time of year its cold
Now, if you have small chamber heads, that's another story... |
I understand the cold weather might be best to try to find out more from the engine builder or previous owner. |
yes 882s 76 cc im going with the 268h thanks for the help
With a 0.041" quench, 0.030" over flat top pistons, and unmilled 883s the CR will be right at 9:1.
If the decks are virgin and there's a 0.041" head gasket w/a stock compression height piston , the CR is about 8.6:1. Less if 1.54" CH pistons got used in a rebuild (~8.3:1). Much less if dished pistons are in there. That said, that assumes a lot. Measuring is the sure way to know- but odds are good the 268 will be OK, and that the CR will not be higher than about 9.25:1. Good luck and let us know how it turns out. |
I hade a bran fart thay are 193 think 64 cc.The cam in it now 488 510 292 302 cam timing intake opens 8 btdc ex 61 bbdc the intake closes 46 abdc ex 3 atdc the truck runs good just not where i need it to
| 350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! | Dizturbed One | Engine | 12 | 08-08-2010 08:50 AM |
| Do oem 350 sbc roller cam's take the same cam bolts as older ones? | eric32 | Engine | 5 | 04-20-2009 04:12 PM |
| Cam bearings 350 chev, cam wont fit in front bearing???? | JD's camaro | Engine | 5 | 02-07-2008 03:33 PM |
| Roller Cam Install - Cam Button & Timing Cover Help | leejoy | Engine | 10 | 12-01-2007 04:28 PM |
| Cam: Calculate LCA (cam°) from lobe center angles (crank°)? | pgtr | Engine | 2 | 09-14-2004 07:28 PM |
