cam help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 10:20 AM
cam help
I have a 70 Nova, tubed, 18.5 tires, auto trans, 454 with 427 steel crank, 10-1 pistons, closed chamber heads. Looking for a radical SOUND cam, not to big/little so as to hurt engine..what should I use...Thanks..commonman
Old 03-06-2006, 03:47 PM
coldknock's Avatar
What does the car weigh?
What converter are you using?
What gears are out back?
Are the heads oval or round port GM castings or do you have aftermarket heads?
What do you intend to do with this car?
Larry
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
Installed New Cam, CAR WONT Start/no Compression? sum87mustang Engine 4 10-27-2003 07:52 AM
