What do y'all think of the cam that i designed?
Cam Style: Hydraulic flat tappet
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 224 int./224 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 268
Advertised Duration: 268 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Valve Lift with Factory Rocker Arm Ratio: 0.477 int./0.477 exh. lift
Lobe Separation (degrees): 104
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
