cam id - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 02:14 PM
cam id
i just tore apart the engine in my 1932 vicky i was wondering what kind of cam was in it it has a 56 or 57 283 with a 327 crank the cam has two stampings one is (GM12) and the other is (3766098) thats the only marks on it ,so can anyone help with that i'v looked on the net but not very hard any help would be cool thanks
Old 05-03-2012, 03:30 PM
BigEd36's Avatar
The "098" cam is the early "fuelie" cam, commonly called the "Duntov" solid lifter cam. Specs are .395/.401 lift, 228*/230* at .050.
Old 05-03-2012, 03:53 PM
BigEd36's Avatar
In '57 the "fuelie" 283 pretty much ruled the street with that grind, the '62-'63 Corvette "fuelie" 327's were pretty fast with the same grind too!
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 10 12-01-2007 04:28 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 07:28 PM
