cam ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 02:16 PM
cam ID
i have a unknow cam from my 300 line..it doers have 560 lift with a 1.6 rockers..numbers stamped on it are BABF 28-5-106lc..785..it is a solid cam
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 04:28 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 07:28 PM
