cam ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 05:15 AM
cam ID
I got a camshaft from a friend I'm trying to get specs on it the numbers on the end are 1264 / 3 09 / 6210 I know it's a flat tappet hydraulic for small block 8 there is a number on shaft 21796 and 09 11
can anyone identify this cam? Thanks
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 04:28 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 07:28 PM
