Cam ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2013, 09:20 PM
Cam ideas?
Ok i got a 466 fbb and im wondering what kind of cam to use. What degree lift etc. i want to take it racing a few times, sound mean, and take it for a two and a half hour drive to indiana to visit distant family once in a while. Any ideas? Link to a cam youd recommend would kick ***
Old 07-13-2013, 09:36 PM
vinniekq2's Avatar
what is your CR,,,deck height of pistons,,cylinderhead flow,,fuel management system,,exhaust system?
Old 07-13-2013, 10:47 PM
73 closed chamber heads redone by ford, not sure exaust system but i know headers, just not what kind, and deck height is a mystery. How do i figure out the deck height? I wanna get that done
Old 07-13-2013, 11:02 PM
vinniekq2's Avatar
measuring deck height
bring piston to top dead center.measure how far down the hole the piston is,in relation to the top of the deck
Old 07-14-2013, 12:46 PM
techinspector1's Avatar
Wiki Edits: 326
Are the heads D3VE casting number? The number is cast into the head just above the exhaust manifold/header flange mounting point, about halfway back from the front of the motor. If D3VE, I believe the chambers are about 95cc's.
Old 07-14-2013, 10:53 PM
Yes thats the code, codes are easy but i dont have the crank or pistons in as of now... I dont even have pistons to go on the rods. And the jack *** with the heads sold them on me and his father couldnt intervien. Otherwise ive got the same but i dont believe they are closed chamber heads
Old 07-14-2013, 11:31 PM
Wiki Edits: 326
D3VE heads are D3VE heads. There is no open or closed chamber variance. The heads have a shelf opposite the chamber to facilitate squish, so match up a piston that has a flat crown in that area. D3VE heads with flat top pistons in a 460 will produce a static compression ratio of about 9.5:1, perfect for pump gas with iron heads. Use a cam something like this one......
Amazon.com: Crane 353932 PowerMax Camshaft and Lifter Kit: Automotive Amazon.com: Crane 353932 PowerMax Camshaft and Lifter Kit: Automotive
Here's the catalog specs.....
http://www.cranecams.com/250-253.pdf
Old 07-15-2013, 12:17 AM
From that i saw one that looked fun and usuable, H-226/314-2-8 was the number, its in the first graph. What do you think? And it wouldnt let me read any other info for the amazon link you sent me besises picture price and bad description with no numbers
Old 07-15-2013, 06:28 AM
vinniekq2's Avatar
do you have headers and good intake
Old 07-15-2013, 09:29 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
The camshaft specs are in the PDF file attachment that TechInspector posted.
Fair idle, performance usage, good mid-range torque
and HP, auto w/2200+ converter, 3200-3600 cruise RPM,
serious off road, heavy limited oval track, bracket racing:
Street, Heavy; 9.0 to 10.5 compression ratio advised.
226/236 duration @0.050, 108 Lobe Sep, .537/.566" lift
I'd think that you'll want some numerically high (i.e. 3.7x:1 or higher) gears in the diff to run that cam.
Old 07-15-2013, 12:27 PM
Wiki Edits: 326
I'm very conservative in suggesting cams for board members here. If you want more cam, buy more cam, but you will need supporting members like a looser torque converter and some shorter gears.
Best course of action would be to get all your specs together, call your favorite cam grinder and ask one of their techs for a recommendation.
Old 07-15-2013, 11:15 PM
vinniekq2's Avatar
cam and gears
maybe you can explain to me why cams are related to gear ratios? I hear so many members recommend gears to match the cam? I think the gears should match the application of the car?
Old 07-20-2013, 10:40 PM
Important question i have and im pressed for time, will 73-79 maverick spindles fit a 69 falcon? And they are currently set up for drum, can they be converted to disc? Please answer quick if you know
Old 07-21-2013, 07:53 AM
vinniekq2's Avatar
gears
Originally Posted by F-BIRD'88 View Post
Accelerate from a stop, starting out in 3rd gear.
Now do it starting in 1st gear, then shift thru 2nd and 3rd gear. Which causes the car to accelerate faster.?
Unless you only criteria is absolute bonneville like top vehicle speed,
it is critical for good acceleration and overall car's performance that the gear ratio and expected engine operating torque rpm range be well matched to the job.
The higher the camshaft duration the higher the engine wants to rev to make its best expected power and torque . The smaller the engine CID relative to the car weight, the more critical the axle gearing selection is going to be.
The short answer is cammed up engines want to rev up to make power and torque and needs gears to do that and get the acceleration you are after.
Otherwise initial acceleration is less than inspiring. A typical car with a big duration cam and no gear or "hiway gears" takes quite a long time to gain rpm from a stop ,,, to get " up on the cam" Then, it runs hard.
A very larger CID engine is much more tolerant of a big cam than a smaller CID of the same engine family, in a said car weight.
It is one thing to have "400 horsepower" or have "500 horsepower". it is quite another to actually apply the power and usefull power range to go fast and or accelerate quick.
this is exactly my point!
not all acceleration contests start from the car being at a dead stop.any car that does cornering has little or no use for a deep first gear(drag racing) The lowest speed I have ever come out of a corner was 40 kph,about 25 mph. At 25 mph I would have zero use for first gear.
If I even just do a simple parking lot event,knocking over pylons,I would constantly be shifting gears instead of just using first gear,that is entirely rediculous.
I do use a 3.50 gear,not the original 2.73 gear because 2.73 gear ratio is wrong for my application.
If I raced my car in the 1/4 mile, the difference between 3.50 gears and 4.30 gears " might" be 2/10s.
my cam is not huge but is big 256/264 @.050,it makes peak power @ 6500 rpm. power band is 35-68,if it was drag car then a 4,000-4500 stall for an auto would be correct. As a standard I would launch at 6500,as a road race care I would just slip the clutch and go,same for hill climb.
the 4.30 gears would be useless for road racing/hill climb/parking lot gymkhana,and highway driving.
gears match the cars application
Old 07-21-2013, 12:00 PM
66GMC's Avatar
A numerically higher gear ratio would work well for almost ANY type of racing, IMO.
The car would just be more responsive to the throttle whether you were accelerating, decellerating, heading into a curve ... whatever.
The "no need for first gear" statement has little bearing on the fact that axle ratio applies to ALL gears. For example, when you're down low in 2nd gear ... your engine speed would be a little higher ... up into the power band.
Looking for ideas myrtle71 Hotrodding Basics 3 05-17-2011 06:08 PM
302 chevy cam ideas ap72 Engine 3 01-17-2011 09:12 PM
Vacuum is no more with my new cam, ideas to stop? 84Z Engine 16 01-24-2007 06:09 PM
cam ideas joseph Engine 4 08-14-2005 07:12 PM
