cam ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2005, 03:53 PM
cam ideas
Hi
have a project car 70 monte carlo w/350 planning to pull & rebuild want to make it a hot street project. have many of the part i want to use but would like a cam with not a lazy lopey idle but a tap dance sound?
The trans is a th350 it's been a long time since i've done any performance tricks
thanks for any help
Old 08-14-2005, 04:02 PM
poncho62's Avatar
Wiki Edits: 5
welcome....if you want it to sound like a tap dancer, back off the rocker nuts....the clacking will drive you crazy.......
Seriouslly, don't know what you mean by that. I will move this to the engine forum...you should get your answer there.
Old 08-14-2005, 05:18 PM
spinn's Avatar
your looking for that high velocity v8 rythme. like the glossy cars at the drive ins have. kind of a bubble not a rumpty rump.
keep your build mild, with lower spring pressures. nice headers and a queiter turbo muffler. something like the dynomax super turbo.
Old 08-14-2005, 05:57 PM
Here's a good performing, nice running, basic
lower cost build:
modified oem Vortec heads for higher lift
available i.e. Scroggin Dickey Chev, Sallee Chev, etc
Performer RPM intake (Edelbrock - dual plane)
Comp Cams HE 262 flat tappet hydraulic cam
full length, small tube headers
Look thru these builds, you'll see there's a vast
difference between some combos, especially
between brands of heads, and cams.
There's a bunch of pages, check them all.
http://ryanscarpage.50megs.com/combos2.html
Some info on heads, and on some similar builds
http://www.corvettefaq.com/c3/goodwr...20part%201.htm
http://www.sallee-chevrolet.com/Cyli...headspecs.html
http://www.compcams.com/catalog/056_057.html
http://www.sallee-chevrolet.com/Cyli...ds/Vortec.html
file:///D:/Cars/Vette/Small%20Block/350%20Quest/Quest,%20Part%201.htm
file:///D:/Cars/Vette/Small%20Block/350%20Quest/Quest,%20Part%20IV.htm
Old 08-14-2005, 07:12 PM
I believe what your looking for is something around a 224 @ 50 of duration or more. The Edelbrock RPM cam would be the raggid edge of a street cam which has a killer idle. Hope this helps
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
did i get the right cam chevellenut Engine 17 07-18-2004 01:51 AM
Cam for 460 EFI? EFI - Does it matter? offroadin Engine 2 06-22-2004 06:49 AM
BBC cam troubles 2wld4u Engine 6 06-18-2003 02:21 PM
cam selection chevyelc81 Engine 9 09-17-2002 06:41 AM
